lee_deathorglory
Morning all
I am joint owner of a 2004 Seadoo GTi 130 4Tec, and last weekend we had an issue with it whereby after just 45 minutes of use the battery was flat.
At this point I should prefix this with the other owner of this jetski is my brother in law who has all the mechanical knowledge of teaspoon and when someone says to him "you need to leave it on trickle charge" he thinks "it only needs to be on for a bit and then I can take it off again!"
Having a bit more technical knowledge about engines ( I spend a lot of my spare time working on my two project cars owned by me and my wife) it falls to me to ensure that its all in working order etc.
So getting back to the point:
We took the jetski out on the coast last weekend, he spent a good 40-45 mins blasting about on it and brought it back to shore so that I could go out on it, it was probably sat for a bout 10 minutes before I tried to start it, when I did it would try and immediately die, with a warning on screen saying '12 volt low' which I took to mean that the battery was low. We managed to get another battery and get it back to the launch where we could get it back on the trailer to tow it home. Where it has since been left on the trickle charger.
So my questions are these:
1. Is it just the battery thats the issue and keeping it on trickle charge will solve this?
2. Is there anything else I can check just for my own piece of mind?
a) One guy while at the beach mentioned that it could be the alternator, however to my knowledge this model doesn't have any alternator does it?
b) If it is indeed a magneto charging system can this go bad? If so what should I be looking for/testing?
Obviously I could just try it again after its been on the trickle charger for a while but for my own sanity I would like to do everything possible to make sure that none of my family are going to end up stuck out at sea on this thing.
Thanks in advance
Thanks in advance
