Found it! No fuse in box. Bilge is oem new. Bilge works fine from main bilge switch but the auto not working. I put a 3 Amp, same as required for bilge on main fuse box. Do you know if sensor in in pump or a separate sensor in bilge?
Getting closer to fix.
The bilge pump is computerized automatic, check if the bilge is receiving power, if yes, then the bilge automatic has a issue. Every 2.5 min should go on to check for water.
Thanks for your help. This am I pulled off the main power switch and there was then easy access to fuse box. 3 amp fuse was blown. Replaced and all works great. Couldn't done with out your help.
Last item I needed to fix before selling on eBay. Again, thanks.
I have a 2007 Utopia with the same problem-bilge pump does not run in auto. When you say "pulled off the main switch", do you mean the on/off Perko-type of rotary switch? Or is the fuse on a Utopia someplace different?
