ALR1955
I've had our 2005 S/D Sportster 215 4 TEC SCIC since new. I've had my share of issues with the boat and I was hoping for a little bit better quality given what we paid for it:
1. I'm on our second engine (Rotax 215 HP 4TEC SCIC) due to the timing belt/chain breaking the tensioner in the front of the engine and "jumping" the valve train out of time and destroying the internal workings. According to Sea Doo there was a "problem" with our series of Rotax engine valves (not really a big published thing) and they agreed to sell me another engine at 50%. ($2450.00 USD) My shop did all the labor and the new engine is doing fine as it was relatively easy to work on.
2. All the seat upholstery is trashed. The seams have come apart on 3 of the 4 seats; the "silver" colored fabric is peeling the color right off the fabric; there are several cracks in the remaining fabric on all of the seats. FYI - we keep the cover on the boat at the dock when it is not being used to help prevent this.
3. The rub rail that is riveted in place has more than half of them "sheared" around the boat leaving the rub rail "wavy" looking. Already removed the entire rub rail and I am going to redrill and use SS screws to remount it.
4. The scupper drain that goes to the back of the boat from the cockpit ALWAYS puts water in the boat if it is sitting still. Of course it drains when it's running. The ball in the drain unit just doesn't do what it is suppose to. I'm changing it to a true "scupper drain" with rubber flap.
5. When I reassembled the back end of the boat after the engine installation, I had to change the hardware configuration on the shifting mechanism to stop the "locking up" and restricted movement of the shifter handle.
These are the major things that I have run into with this boat. I am interested in hearing from other boat owners about any problems - if any_ that they have run into. I am a firm believer that you should not buy a boat or a car made on Monday or Friday - just can't figure out which of those days my boat was made.
:rant:
:rant:
