Workinonjunk
Ok so I’ll try to make this as short as possible, took out my 96seadoo gti for the second time this season, had zero issues with it a couple weeks ago had a long 4 hour ride.. took it out today it ran fine for a bit, then stalled randomly which is odd because it never does that, but cranked right back up. Fast forward 45 - hour an a half of riding i stopped took a break, started again and somehow a small section of rope that some lovely fellow must have cut off their boat, wrapped around my driveshaft. I found out immediately when the thing kept cavitating, so i went in the water and felt around and got the rope off with a knife. Meanwhile it kept stalling over and over as well. it seemed good after the rope was off aside from random stalling here and there over like 10 minutes of riding so i popped new spark plugs in because they were a season old and i thought it fixed it, but it started stalling again at any speed but running just fine other than that. I felt the head and pipe and it was warm but it seems like it was a normal temp. ( i do not have a working overheat gauge ). So i stopped let it cool while i got something to eat and checked it over again as best i could, and couldnt tell anything wrong with it, i took the plugs back out and closed the gap a bit because i forgot to gap them correctly first and they looked normal color. The ones i took out were e3 plugs and they were pretty black, The new ones are ngk Btw i gapped them by eye but just barely closed them since they come gapped at .30 and i run mine at .23. Anyways, i took off and about 3 minutes passed and i was hauling back to the boat ramp because i know something aint right, and it stalled again a couple times and then suddenly click click click, oh great…. I fealt the head, it was then pretty hot more than normal. Then took the pto cover off, and sure enough cant budge it. Had a buddy tow me miles back to the ramp. Pulled the plugs to see if i could free it up but no luck and then noticed the electrodes were pure white… im unsure how that could be since i had just pulled them and they looked a normal carmel color and then 3 mins later the motor locks up and am assuming no oil since they are lean looking plugs.. anyways thats as far as ive gotten with it since this just happened. Any input on what it could have been that caused it and my options would be appreciated ( i already know my wallets not looking good) btw the ski is pretty clean and sending it to a junkyard is out of question, probably.. also im not near rich, which is why im on this forum and riding a 26 yea old ski, its older than i am. Also ive been running lucas api-tc semi synthetic oil. Rebuild the carbs last year and new fuel lines. Is it possible the oiler just quit? How should i go about testing it and is there a chance i get this motor unlocked that it will work again lol. Also since it got something stuck around the drive shaft could that have something to do with it? I originally thought it sucked up something(the damn rope) n clogged the cooling system but after seeing those plugs im not sure.. anyways thanks guys
