rksnow1
I know this topic of the RAVE valve has been beat to death and I just read 50+ posts and didnt see my exact issue.
I just replaced my grey fuel lines with new lines and cleaned my Rave valves while I was at it. While cleaning the valves I noticed both red caps were set differently. One was set almost flush and the other almost all the way in. After reading the posts here I set both all the way in. Is it normal that these would be different? I dont recall which valve was set which way either to turn back.
I did also clean the water reg but didnt adjust that cap. Today I took the ski out(97 GTX) and although my previous fuel hesitation issue is gone.. I have no top end speed, at WOT around 6500rpm, then like a Rocket booster, I can feel the valves open and the rpms hit around 7k and we take off. Feels a lot like turbo lag on my wrx sti, only no 5th gear wheel spin.... Prior to these adjustments my throttle response was smooth through out the range.
Does anyone have the factory settings for the caps handy? What should the setting be for the water reg cap in case I did change it somehow by accident.
Thanks again
Thanks again
