Hawkster18
I have a 96' XP and decided it was time to fix the fuel gauge, watched a couple videos and said no problem. Pulled the tank, (it needed to be flushed out anyway) took the fuel baffle out, cut into it like all the videos showed and looked inside. There is no F1 fuse! There is a R1 labeled resistor on top then below that is a FU labeled (little yellow maybe fuse looking thing) then R2,R3,R4 and so on labeled resistors, but nothing staiting F1. Is this a aftermarket fuel baffle? If so I would assume that the FU would be the fuse....correct. Any info would be great, so I can get this low fuel light to turn off. Thanks!
