Adjusting steering on 150 speedster
hancop
Hi everyone, I have a new 2012 speedster and just took it out on the weekend for the first time.
What I noticed right away was that I had to hold the steering wheel a full 1/4 turn to the right to keep it going straight.
Is there and easy way to adjust the steering ?
Thanks
yes, the steering nozzle can be adjusted. If you look back down by the jet pump you will see where the steering cable attaches to the steering nozzle. That attachment point has a fairly long adjustment screw with lock nuts on it. Just loosen the lock nuts and turn the adjustment screw in the correct direction to dial in your steering. You may need to take off the reverse bucket to get to the steering nozzle, but other than that it is an easy job and you only need a few simple tools.
