Steering Wheel Alignment
Chunkd
I have adjusted my steering wheel straight with my nozzle and everything is in line but now I can rotate my steering wheel more left then right by about 45 degrees.
How do I adjust my steering cable so my steering wheel rotation is the same all the way left and right?
Boat is a 2012 seadoo 180 challenger.
Thanks!
Here is what I would do.
First you need to make sure your steering is centered because it sounds like it is not.
There is not much adjustment at the wheel pivot arm so you have to watch the motion of it and determine where the center is based on the arm movement alone. Ignore the pump alignment for now.
Once you figure out where the helm mechanism is Centered, you need to hold it and then adjust at the pump.
If the steering wheel is not centerd when the linkage arm is in the center, you may need to pull the steering wheel off and center it.
Last is always the pump.
