Depending on how deep you sink your trailer to launch, these might not be worth it. We use the pole guides and they work like a champ as they stick up quite a ways and provide you with something to bounce off of when coming in on a windy day or an area where the current is strong.
Any pics? Have been looking into adding
I added these. I was having problems where boat was tilted sideways and I didn’t notice till I pulled the boat out. I would then have to put the boat back in the water and level it out. After adding these the boat glided in straight and level.
Here are the guide poles we've been using for a couple of years now.
View attachment 34499View attachment 34499
I did the bunk ones. I also find that since the boat goes in straighter it glides onto the trailer better. Also since it's on straighter it's a lot easier to use the hand crank. I'm a newbie to boating so i'm not that great at getting the boat on the trailer so these helped a lot.Slaizer did you add the pole style or bunk style?
I believe the 230 is about 3"wider than the 210 (8' 6" vs 8' 9" beam). The guides on my trailer sit out just a couple inches past the fenders. Yes, they're supposed to be spaced enough to allow for the fattest part of the boat to make it through, but by the time the fattest part is near the guides, the bow should be making contact with the forward bunks up to about the middle of the boat.
This should prevent the rear end of the boat from swinging. You may need to adjust the depth at which your sinking your trailer to allow for the boat to be seated on the bunks when putting the boat back on the trailer.
I've had my guides for years with no issues......and I've had to put her on the trailer in some nasty storms. They're not always graceful, but I have yet to damage my boat since installing the guides.
I'd add some crash pads to your poles for a little added scratch protection. The added thickness may also help to keep the boat from swinging too much.
I feel your pain. The hourglass shape of these boats does it make it tough in adverse conditions to get the boat centered on the trailer. Our last boat ('92 Ski Nautique) was straight down the sides of the hull. The guides worked much better in keeping the boat from swinging while placing on the trailer.
Some things we've tried on windy days:
Person in boat goes to guide poles and either pushes or pulls the boat square with the help of the truck driver.
Same as above only wedge a fender (we use an inflatable kids hippity hop ball) or something between the guide pole and the hull on the "push" side of the boat.
3rd and last resort is to hook the bow and have the person in the boat use the motors to "steer" the boat straight as I pull the trailer out of the water. Our boats can swing left to right fairly easy and this has worked when all else has failed for me.
90% of the time I'm good to go, but on occasion I have to try any of the above. Not having anything below the waterline to give bite does have a few downsides, trailering in adverse conditions is one of them.
