Waste of money if you ask me. If the seals are good, there shouldnt be leak.
Living on borrowed time. It´s also leaking while you´re using it. Just my two cents.
One point to make here...there is no reason to put a valve on the hose coming from the left side of the motor. Just put one on the the hose under the carbs.
Some of you may be interested in an oil solenoid valve kit I have been working on. Instead of the ball valve I am using a flow control solenoid that will go into the line just like the valve, this solenoid will operate off of the MPEM and will cut itself on when the machine cuts on and off when the machine cuts off.
It will come with its own harness and it will be plug and play into the existing wiring. I am still trying to decide if I can run it off the gauge circuit of the MPEM or if I need to run it off a separate AC voltage sensing switch which is why it is taking a while to get all the bugs worked out.
I plan on introducing it along with a few other Seadoo specific products I have been working on this Spring or Summer, the fuel line kits I posted up were one of those products.
