SeptemberC
Steering cable bolt broke. Does anyone know what size SS bolt it is?
YES I've been using PB Blaster for 2 weeks.
The bolt isn't a big deal. It's a standard 1/4-20 bolt. Head to the hardware store, and get one the right length, and a new nut. With that said... the old nut was a locking nut. (you may see pressed in edges) You want to get a replacement that will lock. (I recommend a nylock style) You don't want to lose steering !!
After looking at my boat... the manual... and some parts explosions... I think I would use a couple ratchet straps. Hook them into the edges, bolt holes... or cable holes. Hook them up to the loops on the transom where the trailer straps go. Then... put a little pressure on the ring. It may start to move... but if it doesn't... tap on the ring with a metal hammer. (not wood or rubber) You want the shock of metal on metal. Then... go back and forth with the hammer, and tightening the straps. It will pop eventually.
Some smart chemical person needs to develop a product that can be applied to things like this that will soak in and break up Salt water corrosion. .............
.. That bolt had a smooth top to it I'm assuming where the Heim joint is. Did you see my picture of the bolt above?
They have... it's called muriatic acid. BUT... that eats everything if you aren't careful. The issue is... when aluminum (and most metals) oxidize... it expands. That expansion is what sticks the parts together. SO... you need something to eat away the "Rust". But, since aluminum is soft... it quickly eats the good metal too. Things like PB Blaster go in, and help break up the loose stuff... but doesn't do much for the actual expansion.
Keep tension on it... and use a heat gun to warm the ring. You may need to do a couple heat/cooling cycles... but it will pop. I don't like to use fire in this case, since something could ignite.
I'm not following you on the cable. Can you take a pic, and point at the part?
ok. Now I see what part of the cable you are talking about. Yes... with that nut off... it should pull out. But, since the cable is ridged... you may want to loosen the clamp in the hull, so it can actually move back a little. (don't want to rip the rubber boot inside)
Fingers crossed on the ring. (try tapping too, since you used heat)
I had the same problem with my salt water corroded jet drive.. I ended up replacing the steering cable because I knew it was pretty beat from the salt water and I didn't want to fight with it without damaging it. I cut it off and replaced the cable. I used the old cable to fish the new one through the hull. I'm not sure how easily accessible your steering column is but it's easy on that end if you can get to it. The through-hull bellows at the jet drive isn't bad either, assuming you can get to it easily enough. Food for thought.. I think the cable cost me around $140ish.
On the ride plate.. did you hold the nuts on the back side?
I just recently did the same thing other than replace the steering cable. I too had a heck of a time getting the bolts out and my boat is in fresh water. I had to get replacement screws for the ride plate from Fastenal special order only cost me $3. I tried Home Depot, Lowes, Canadian Tire, and Home Hardware. I used anti-seize when I put them back in. The replacements were Alan Key socket heads.
I repaired the wear ring using JB weld. From my research to replace only the wear ring is doable but very difficult. The wear ring has to be cut out and a replacement inserted. It's a shame that mercury only sell the wear ring housing as a kit at around $600. Maybe I was lucky after several hits with a rubber mallet and some elbow grease the housing came off and the steering cable slid through the hole. Something to be said for fresh water. Do you have the mercury manual for your engine?
