1999 challenger 1800, twin 787
Hello everyone. Happy summer.
My starboard engine is "flat in the middle". Is idles ok, accelerates ok to 2.5k, hesitates, then jumps to 4k or more and runs ok. Above 4k it can run ok, but will fall off. I need to feather the throtle to maintain a steady rpm..
If I drop from high RPM to low RPM, the engine will stall.
When running at idle there is a low speed steering assist on this boat, where one engine will rev if the steering is turned to the stop. During low speed steering, the port engine jumps from 1.5k to 3k. During low speed steering, the starbord engine only jumps to 2.1k and is gagging.
Searches on this subject point to a accelerator pump problem. Is there anything else that could be wrong?
