a question about carbs 720.
cuenta
seadoo xp 95 720cc
I know the set up is low 1 3/4 and high 0
what happens if I open a little the high
the mixture is enriched or lean
thank
seadoo xp 95 720cc
thank
Makes it richer--> may lose top speed rpm-->foul plugs when at idle for long periods.
Questions is why do you have it richen it? Are the plugs tan when you chop test them??
Yes i want richer because the cylinder block
Is little hot maybe 150 degrees but the head and pipe are really cold
Or is normal what the cylinder get this temperature
This is normal, and it's why you cannot use TCW-3 ash-less oil for low-temp engines but must use low-ash oil for high-temp 2-stroke engines.
It's very good you are checking this though, to become familiar with your ski as you should.
ok thank for the info.
and go for the water today saturday
