Hi again:
Following up on earlier advice and what I've since read in the owners manual. Earlier I posted:
Hi all...I'm new to the forum, so I apologise if this issue has been dealt with previously. I am a new owner of a 2008 Seadoo Challenger SE (only 16 hours on the boat). I just took delivery of it yesterday. It had been in winter storeage. Naturally I had it out yesterday, things seemed to be working nicely, and after about 20 minutes on the water there as a single long warning beep and the check engine message started coming on. It also displayed a code "P-0111".
If anyone has any idea what the problem would be I'd appreciate any advice.
I got some great responses for which I am thankful.
Someone looked up the code and found that it was "Intake manifold temp sensor Faulty"
I have since messed around a bit with the boat. Went out today and again got the same warning. But I also read the owners manual about fluid checking. It said that oiled should be checked when the boat is at a running temperature, not cold. So I did and found the levels 30 mins after running it were about an inch above the top level. Am I reading the manual right? I did an oil level test when the boat was cold before and it was in the range.
If there is too much oil ...(stupid newbie) how do i deal with that problem?
Any help would be appreciated
