99 XP LTD - No Power
grandsammy
Hello my jetski 99 xp seadoo ltd, I was running all day in the lake and everything was perfect until the jetski shut off, the battery fuse was burn it so I replaced it and still got no power, I removed the vts fuse but still no power, I check the battery and is 100% charge, I reseat the cables for the battery and all the cables in fuse box and still no power. do you have any suggestion?
MY 1997 800 xp had a problem like that. yours could be a bad ground. ours was a m/f plug. i was a very small plug near the starter cellinoid.
also check all the electrical plugs. something simple as a little corrosion inside one could cause your problem.
