99 SPX problems
Alexlc
Ok well im dealing with a 1999 Spx. For some reason i am not getting any fuel to the spark plugs. Ive tried looking at the on off valve for the gas, and everything is good. So from there i tried putting fuel directly into the carbs and still nothing. It looks like the gas is even spraying back out of the carbs. Does anyone have any other ideas of what i can look at to try to get fuel to the motor.
Thanks
Was the motor, ever apart??...also, with plugs out, and pto cover off, check to see what way pto is turning, while try'n to fire. Should turn counterclockwise....itsa start
It's possiable the the carbs need to be cleaned.
It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too.
Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Keep us posted on your progress.
Karl
