AggieDad
I purchased this jet ski a year ago and after a few times of it working perfectly I started having issues - it initially started fine and then not wanting to start again - not even trying or clicking. If I let it sit for a bit it would start up again. The battery seemed OK but the voltage rectifier was not putting out enough volts to recharge it, replaced that, but still had issues. I pretty much gave up on it last year and rode my other ski. This year I finally installed a new battery and although I get the red LED to come on when I install the "key" all I get out of the starter is about a half second of crank each time. I even tried jumping the battery in case there wasn't enough cranking amps from a car battery but same issue. My question is, where do I start my troubleshooting? I am an electronic engineer so electrical troubleshooting is my thing, but I am not an engine guy. Starter switch, solenoid, starter, frozen shaft? Any help would be appreciated.
