wash-i-taw1
Looking for suggestions to get ahead of potential troubles with a ski that is not having much for issues (It is 22 years old). The only things I have done to this ski is to rebuild the jet pump and change out the old fuel lines to the black ones. My only issue seems to be a starter that whines (spins without engaging) occasionally when you attempt to start. I replaced the old fuel lines, but only after about ten years of use and reading about the issues with them. I do get a sort of metallic rattle that sounds to come from the jet pump area and have no idea what that is. I have ran Amsoil for nearly it's whole life.
I am thinking of a top end job, but also question whether I should pull the carbs and rebuild while I am at it. I still use the oil pump, so not sure if that should be gone over as well. Also would like to fix that starter issue. Thoughts on what would be the recommended approach? I am pretty mechanically inclined so would be doing it myself. Any good links for rebuilding the top end on this 951? Thanks for suggestions.
