I bought my gsx a few months ago and just recently got it out on the water.
It started and ran beautifully for 2 outings (3-4 hours of riding). But the 3rd time I took it out, I needed to add a little throttle to start it. Then while riding it would loose power and die (in about 4 seconds). It did that a few times then worked just fine for about 30 minutes. Then I brought it down to idle and it stalled. I started it up a few times and was seeing the tachometer drop into the 700-800 rpm range and it would die. If I added a little throttle and kept the rpms above 1000 it would run just fine. I started it up in my driveway today and it still wont idle on its own. I don't know if the idle speed is out of whack or if this is a sign of something else. I looked at the plugs and they are a little dirty, but shouldn't be the problem. Any ideas?
1999 GSX RFI
compression is good
fresh fuel
half tank of oil
I took a short video of me starting it.
http://www.youtube.com/watch?feature=player_detailpage&v=Tu_WaBif2Ys
1999 GSX RFI
compression is good
fresh fuel
half tank of oil
