AKnarrowback
Quick background.
I bought this machine in running condition but had low compression so I only started it on the trailer for 30 seconds to make sure it was a runner before I went into the top end. Cylinders were bored/honed, OEM oversize pistons in, all new gaskets, a little sealant on the manifold to pipe gasket, original mikuni rebuilds/needle seat/accelerator pump, old gas pulled out, all new fuel lines, fuel selector still good.
Machine started right up after the rebuild and the motor runs as it should for the first few quick test runs I have done.
The problem I'm having is water building up in the hull fast enough where I don't want to run it. The bilge pods and electric pump seem to be having a tough time keeping up.
I know I should be able to figure this out with my experience on these things, but since this is a motor and hull I have zero experience with I thought I'd ask the crew if a 98 xp limited with the 950 had any quirks/failures that would let Water in?
I have let it sit in the water, no obvious leaks.
I have run it on the trailer at the same rpm 5500 that I ran for the test runs, no water spraying from exhaust gaskets or anywhere else.
Any tricks on this machine I should know about?
Thanks.
AK
Thanks.
AK
