Sportster-2001-951C-Stock
I have a hard time believing it's the MPEM, I could be wrong though.
Any way you can measure the system (battery) peak high and low voltages nearest to MPEM as possible during start up of 2nd motor? I guess it shouldn't dip under 10V and shouldn't rise over 14.4V.
Eliminate battery switch to isolate something going on there?
Have you looked inside the ignition coil box where the starter solenoids also are, corrosion on ring terminals (especially the grounds) in there is pretty common.
When I had my cover off, the silicone gasket was pretty dry which made it challenging to get back together so I had to lube the gasket using some silicone spark plug wire grease. Or maybe I used some sludge on my finger from the bottom of the bilge, I don't recall exactly....
