bountyhunter
Need expert advice.
Symptoms: 15A fuse labelled battery on the MPEM keeps blowing.
First, I unplugged the two plugs that connect to the rectifier with no luck. Fuse still blows. Only way to keep 15A fuse from blowing is to disconnect the plug that connects to the top of the electrical box that contains the ignition coil and starter relay. Any clue what the root cause may be? Thanks in advance.
