kgray61340
If the magneto ground wire wasn't hooked up to the other motor would that cause that motor to not run correctly ? It would run but I thought it was carburetor so I got a new one but still wouldn't run rite so then I was thinking it might be the timing because it was running so rough and while unhooking everything I came across this ground wire that hooks up to the other magneto cover could that be my issue or should I continue and do a pressure test of motor and check the timing since I have everything unhooked ? I'm new to this and haven't even been on water yet the guy we bought boat from said it was running great I thought I did something wrong when we tried to take it out the first time and I thought both motors were running and I was up and down on throttle for a while before realizing only one motor was running so be gentle and. Thanks in advance for your help ! Kevin in sc
