Mike99
I'm replacing the tempo fuel lines, and see that OEM was 8mm and 6mm in size, based upon what is stamped on the hoses. It looks like most is plumbed with the 8mm, and a 6mm fuel return line. All the threads I have run across talk about using 1/4" line, but I'm guessing that since this is a 951, I should be using something bigger. 8MM is pretty much 5/16", so I bet I need to be purchasing the 5/16" instead of 1/4", right?
Thanks,
Mike
Thanks,
Mike
