did some lookin around cant find a cut and dry answer. when i charge the battery it starts and runs fine but while running the 12v low light is on the entire time. i dont know if its charging or not. i took an ohm meter to the solenoid and it ohmed across the posts (battery unhooked). when i unplugged the connector with the yellow-red tracer and black wire it still ohmed. but when i unpluged the red-purple tracer wire on the 15a fuse it no longer ohmed. the diagram dont really say what the red-purple wire is for as far as i can see. i put everything back together it no longer ohmed and started right up but 12v still on and when i unhook or hook up the battery it sparks pretty good i dont think that should happen. any help is very much appriciated. im gunna give up on the spx untill winter but i would really like to get this one on the water this summer!! thanks a bunch
