97XP locks down
Turboman
Hello everyone. I have a 97xp, that the motor turns over freely by hand or starter, but when I install the spark plugs it won't turn over by starter. Now I have eliminated this to the front cylinder. I can install the plug in the back cylinder and it will spin. If I install the front plug it won't. Any help would be greatly appreciated. Thanks................Turboman
Could be a low battery , weak starter or both.
Should check compression also if you can.
Doing those things should tell you a lot.
Have been through most of these issues with my 96 xp.
Good luck!
this is like, the exact thing what is happening with mine. mine is full with gas though :o
i think i have to take carbs and put the needle back in its seat, but i don't know.
when you crank, does gas spray out?
