I can't turn the starboard engine. Ran fine last week for a while and then seemed to lose power and couldn't get it over 3000 rpm. I checked the impeler and didn't see anything obvious there. Thought I might have a carb problem. Broke the carb down and cleaned the fuel filter/basket. Its been sitting a week and now I can't turn the engine at all. Try spinning the harmonic balancer both ways and it seems locked tight. I look in the impeler shaft again and there are two small white pieces of plastic sticking out right where the impeller shaft enters the hull. Too small to grab with anything. Has something broken loose in there? I've looked at the schematics but can't figure out what that is that could be binding it up. How do I get at that? Have to remove the boot and outside jet or can I get to that from the inside? Port engine is running fine.
