Fat Tony
So, I have a miss on my port engine when trying to get up to speed. It will sputter for a moment or two not climbing above 4500 rpm, and then it will finally surge up to about 6200. it did this a few times and then it basically would not rev at all, would want to die if cracking open the throttle. Granted this boat sat for a year or so, and I have run about three tanks of fuel [premixed] through the system, but it just started doing this the last time I was out. The engines have less than 60 hours on them, as they are premium rebuilds from fullbore. I am fairly sure that it is a carb issue, maybe some junk picked up from the tank and some of the old gas I was unable to get out of the system, or debris from sitting for so long [and apparent lack of maintenance from the previous owners]...
So, the question is... pull the carb out and soak it in is a carb cleaner solution, or do I break it down a do a rebuild? I'm not sure I want to be the one to attempt the rebuild, but if so, what kit would I need. I am having a bit of trouble determining which Mikuni kit to buy for these carbs as they seem to be a different size than the previous/later years.
If rebuild it is, then I am wondering what it would cost for me to ship them out to someone like Waterluvr to rebuild it? If I do one, I may as well do the other, I think. I have already put a small briefcase of money into this basketcase, so now the wife is starting to watch the expenditures and need to be able to keep the spend tighter than just tossing money at it...
Recommendations?
Recommendations?
