I want to add a bilge pump to my old Seadoo BUT I’m not crazy about the idea of putting a hole thru the hull for outlet. I’ve been doing research and found another poster with my ski put it thru hull on the side but it fills up his foot well with crappy bilge water (also not good). I have very limited space on the back of the ski do to this enormous hollow plastic engine vent system in the back. I suppose as the jet ski is moving forward air moving across the back vent sucks up air from the inside tube and draws it out the back. I was considering just putting the bilge exit port to the back of one of the vents drilled into the plastic behind it for the bilge water to just flow out the vent. The way the vent is designed I don’t believe water can travel upwards the exhaust vent and back into the engine bay versus just going straight out the back vent the way that tube is designed. I just wondered if anyone else thinks this may be a reasonable solution, poking hole in this plastic piece versus hull and still being able to see water coming out of vent. I would still put a high as possible loop between the bilge pump and the vent outlet just for extra precaution and that vent is above the water line. I attached photo of vent and the blue lines is what I believe is the airflow. The red X marks where I consider to install the outlet. The other picture is the vent on the back of the ski. Thank you.
