Sparkieboat
I got a 97 GTX, it has always read 12V low on the read out since I have had it, but it always ran fine. The beeps are muffled and can barely be heard, but I do hear 2 faint beeps when I put the dess key on the post, it will not turn over when I press the red button and does not have fire when I jump the solenoid. battery is fully charged and spins the engine over fine when I jump the solenoid. the connections appear to be clean and tight. and I have checked the fuses. when I press the start button one time (with the dess key off of the post) the gauge comes on, after that if I double tap the start button it will beep once then briefly flash hi temp then go back to direction SWest.
I tried disconnecting the temp sensor wire on the top of the head with no change.
After doing this a few times now suddenly my beeps are crisp and loud. the 12V low still flashes when I try to start the motor with the dess key on the post. It has read 12V low since I have owned it but never gave me a problem before.
Any ideas?
Thanks Sparkie
Any ideas?
Thanks Sparkie
