97 gtx help
tesmathers
ok guys just bought 2 97 gtx s one runs awsome other says hi temp and low oil. oil is good replaced temp sencer. runs in lemp mode at 25mph checked comp 130 lbs both cylnders any ideas would be great good with the old early modell seadoos but this one has got me.
yea changed that too when replaced temp sencer what else will put it in lemp mode??????? dont want to take it too dealer but those boys here are crazy $$$$$$$$$$$$$ im just a poor boy
just so im right u are talking about sincer in oil tank? also is ther a reset some where cause it can set for 24hrs as soon as u crank michine it says hi temp this one just makes no since. keep it coming boys thanks
You need to add you seadoo model and year to your avatar so we can see it when we answer your question...I don't have time to keep looking for your information each time I answer. What beep sequence or codes is it displaying?
Karl
you could have a problem with the oil tank pressure, could be a problem with the rave valves. hard to tell!!! could be the battery. there are alot of things that throw one into limp mode. holding the "mode" button for 5 seconds then "set", should reset everything, codes and such. i was told batteries are everything in seadoo's. more voltage = more speed. could be a battery issue?????? shot in the dark my friend!!
mine has always had hi-temp and low oil notifications. they would come and go almost everytime i ride.....maybe thats why she shelled!!!! hahahahah
lemp??? michine??? modell??? senser??? cylnders??? swetching??? thow??? sinser??? what is all this madness??? I'm so baffled by your spelling that I can't begin to figure out your problem... I hope you can talk better than you can spell....
hi-temp warning
My 2003 GTI LE RFI does the same thing and getting worse. Now it does it after running only a few minutes, if that long. Once you stop, you have to let it cool down over night, although it never felt particularly hot. Would this be the water temp sensor, or water pump? It only has 78 hours on it, but has been doing this to some degree since I bought it with 60 hours on it. Nice machine, but my next will be a Yamaha or Kawasaki.
..........:lols:
