i took my ski out today it ran fine for awhile then it started to bog out. taking off was fine 1/4 throttle was good wot it goes bogs goes bogs any way you get the idea i am thinking fuel filters maybe or carbs ? any ideas thanks for your help
hey...check compression, ideal is 150psi, make sure you ground plug wires to post/s, then check inline filter, fuel selector valve, replace the lines if grey,...last time carb/s were gone through?
i have only owned the ski for about two mounths so i dont know when any of that stuff was done i have changed the plugs oil stuff like that i have the fuel baffle on order so ya i will check that stuff and repost
