Update - Again no spark
Finally got the GTi back in the water. It ran pretty good for a while, then shut off. Started right back up and ran for about 10 minutes, then shut off but started right back up. Third time out, ran for about 20 minutes and then shut off again, but this time it would not start back up.
Got it back home and checked again, and not spark. The new magnetor coil is reading about 60 ohms, so it appears to be OK. The ignition coil (in the rear electrical box) reads about 1.5 ohms. Specs say that should read about .5 ohms.
With the intermittent issue and then full dead, would that likely be the ignition coil, or back into the magneto again?
