97 gti fuel pump
brian1987
i got a 97 gti it was run dry on gas and hasnt started since took carb apart looks good i think its the fuel pump. if i take off the lines from the pump i can blow gas out with my mouth. I tried that and turned it over and as long as i blew on the gas line it would run so the pump must not be working right? or could it be someting else?
Welcome to the seadoo forum brian1987. I would take off the carbs and see what the problem is. The fuel pump might not be working or it could have a bad diaphragm in the pump. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
