I purchased a 1997 GSX a couple of days ago. 134 hours, 140 and 141 pounds compression. Seen that it had the Tempo fuel lines but I couldn’t wait to get it out on the water especially since these may be the last warm days here in Ontario. I did remove all the old purple oil from the oil reservoir and filled it with XPS oil. First time I took it out It ran fine for about the first 6 or 7 kilometers and then it started sputtering more so when I gave it lots of throttle so today I changed all of the grey Tempo lines which did have the green goo as well as some rust like looking stuff. Also took the filter out of the carburetor and cleaned it. Took it back on the water today and thought I had it fixed, ran great for about 7 or 8 kilometers and then started sputtering again. I’m really thinking it’s a fuel issue, perhaps something to do with the water separator located just back a bit under the hood? Or Would the fuel valve cause this type of problem? I’m going to check the filter in the carb again. As it did run great for 7 or 8 kilometers. Any help is appreciated. Thanks
