97 GSX SEadoo 800
Rick Spiess
Engine burn a hole in exhaust hose ski fill up with water.got engine running next time went to use found rear elect, box full of water ,remove water change starter solened & repair hot lea to harness. now alarm go off when engine is running How to fix???
The hole in the exhaust probably was caused by corrosion, not heat. (If it was heat, you have way worse troubles than the exhaust!) So, I'd compression check it, and if all was good, I'd JB weld the exhaust hole. Be sure and CLEAN the hole real good, and back to GOOD metal. Dremel moto tool would be handy to do this. Small wire brush on end of electric drill would do it too. What you want is to CLEAN it good, and then if it became a big hole, while cleaning, place a bit of screen from a metal screen door on it, to hold the JB while it dries.
Your post is a bit sketchy from there... are you leaving it in the water? Has it been run in salt water?
The alarm, sounds like a temp alarm?
If so, seriously flush it out with a hose. I'd even turn it on it's side, (maybe not 90°) with the hose on, and motor running, to get the sand or other junk out of the head. Look up "flushing sand" or "Flushing debris" with the search function.
I have not had to flush mine like this, but I have seen pics of the areas that trap sand, and other stuff, and prevent the cooling sys from functioning right.
I hope this gives you some ideas, on where to go from here.
Nate
Hole was in plastic where exhaust exit hull , all repaired
with hose on trailer .
blew out with compress air.
how to test temp senser?
I think this is what you are looking for:
To test the temp sensor you need to have a multimeter. Check the sensor to see if it has a open circuit. Then being careful not to get burned put it in a pan of water. Bring it up to about boiling point...212* Be careful not to get burned...check it again. Now it should have continuity between the bottom and the top connector. Also if you take the wire on the seadoo, and just ground it, it should sound the beeper, with the lanyard on. The sensor makes contact to ground when it is hot and activated.
I hope this helps.
Karl
This forum is LOADED to the gills with good info!
Enjoy.
Nate
