dsteinmann
JUst bought this 97 GP1200 Compression in two outter cylinders is 110 middle was about 50.
Next i looked at the oil lines
Looks like two Are disconnected / Only the flywheel is hooked up I guess this is the only place it injects oil
So I Guess it suck it through the crabs only??
The two good clyinder look great can still see the Crosshatch. The MIddle one the rings are seized to the piston and a few groves in the wall not really bad? What do you think?
So It looks like the the Crank is dry on that cylinder also the bottom bearing seems fine no side to side play more than the rest
What you think I should do?????
Replace oil lines and longer
New #2 piston rings and bearings kit
What about the wall? Could i buy a used stock sleeve (no machineing
