I recently purchased a 1997 challenger 1800 port engine runs , starboard does not run .
Compression 150 both cyl.
Both sets carbs have been rebuilt.
2 beeps on dess
I check for spark i do see spark although it looks weak and random.
I put a regular timing light on port engine fired it up light flashes .
I put timing light on starboard and tried to start it flashes but it looks as if its intermittent flash.
Pulled starboard stator did ohm test on trigger coil and stator checked good.
Not knowing for sure if stator is good, i took all electrical from port and swapped to starboard engine , swapped power from solenoid ,swapped stator plugs , and plug wires . And starboard fired up .
So this tells me that everything on the engine itself is good and one of the components on the boat is what is failing . Coil, regulator , on/off button ? ,MPEM ?
Any ideas on where to go from this point ?
Thanks
Frank
2 beeps on dess
Thanks
Frank
