rotaxrule1
Hello,
My 96 XP that I recently purchased has not run too well since I have had it. Here is whats going on:
Starts up ok usually, idles just fine in and out of water.
coming out of "no wake" zone sometimes bogs to the point of wanting to die until I ease into the throttle and let it climb. (intermittent issue) Other times it runs right up to 6500 RPM (guessing by engine tone) and climbs right out of the water.
The other issue that is always consistant, is the top end speed and RPM while on plane at full throttle seems to be lower than usual. (my 97 GSX smokes it and they have the same 787, both 110 HP, I think) This seems to always be triggered by hitting little waves that cause the jet to momentarily jump out of water.
It just seems sluggish, it runs "ok" but I would guess it should be much faster. It does have the original grey fuel lines (plan on changing them soon), and basically everything else is original it looks like. It makes no difference whether the fuel selector is on reserve or on position. Compression was between 140 and 150 on both jugs when i checked it.
Anyone have any ideas or pointers by chance? I wonder if the raves might be plugged or adjusted incorrectly. Sorry I am new to tuning these things, I have less exposure to rotax engines than my other atv engines and such, so I would love to learn from you guys as you have been great help already. Thanks in advance for any help!
