96 xp jetting
2ballsdeep
I know this might be a vague question, but i just put on some ocean pro air filter/arrestors and before i drop her in the water, is there any special jetting I will need to do now that the air intake is less restrictive? Any suggestions? Besides that the bike is stock. Thanks.
with less air restriction, you'll need to lower the "pop-off" pressure in the n/s (needle and seat) assy.
Heres the stock set-up..
1996 XP 787 (2) BN-40I (SB) MAIN-142.5 PILOT-70 1.5n/s 23psi - 43psi LOW(lsa)- 1 HIGH(hsa)- 0
Have read, where with install'n those/less restrictive filters, need to lower the pop-off to around 20psi +/- few psi, inwhich a 2.0n/s and "black" springs/80gm, will do the trick.
.......have this set-up if needed.....
As for jetting, i'm sure you'll need atleast a few sizes bigger for each of the pilot and main jet, butt will dig around, see if cant find what sizes.
...need 75lows and 145mains..3/4 turn from closed and start out there then adjust as necessary to get good accelleration while still maintaining a fairly clean idle.
, and 0-hsa/mag, 1/4-hsa pto.
Thanks. Keep me posted. I live in Murrieta and would like to take this thing out soon.
