The fuel level & trim position do not work, the low fuel light is on. (it's full) the oil light comes on when you first put the key on it, then turns off. (like a bulb check)
It died after riding about 45 minutes and the battery was too drained to crank over. So it doesn't seem to be charging. What's the best way to test that or any advise is much appreciated! The battery and starter are new. They were replaced when I installed the new cylinders. So this was the first time I have had it running. It also takes a second for the starter to start spinning after you push the starter button. So I replaced the starter for that reason along with a sign of excessive heat at the starter cable end. (Melted rubber cover on starter bolt) The battery was just old. It will click when you first push start, then after about 1 second starter will spin.
TIA, Randy.
TIA, Randy.
