myclubsoda
Hello evryone,
I just bought a 96 xp with the 787 engine. The fellow I bought it from informed me that the motor was overhauled a year and a half ago. I can see new gaskets through-out the engine so I believe him.
When I Made an initial inspection I found the 7.5 amp fuse in the coil box blown. The short turned out to be in the vts module, this due to water ingress through the boot of the cable. So, I have the vts system disconnected at this time.
Here is my situation, engine will crank and seems it wants to start but won't. At times it will momentarily fire (1-2 sec). If I let it sit for about 30 sec or so and then crank, it will fire and run for about 5 seconds. When it fires There is some intermittent pops, perhaps a lean mixture, then it either stalls or runs at very low idle like its not getting enough fuel and finally stalls.
Here is what I know, I have fuel in the tank, my filler cap is loose, my in-line filter is clear and full of fuel.
I am new to the world of water craft and any help would be greatly appreciated. Thanks,
