Just bought the ski and put it in water and acted like it had fouled plugs, changed the plugs and it seemed ok, but after shutting it down for a while it did the same thing. So I decided to rebuild carbs, got the kits from OSD, all oem parts it says. Installed everything, going by the carb rebuild thread. The only thing I didn't replace was the springs, because the pop off seemed good to me, at 36-38, would it cause problems being off 2 psi on the pop off?
Put it all back together and it did the same thing, only now even putting in new plugs didn't help, it just seems to be getting too much fuel at idle or just off idle, because it starts and idles good, but as soon as you hit the throttle it just bogs down and runs worse, like on one cylinder.
One question I have on setting the pop off, is when I checked one carb I just slipped the hose on and pumped it up, but on the other carb I had to put hose clamps on the hoses otherwise it would just leak air out of the connections. I couldn't just use my finger to block off the one hose either, it would just leak. Is there something going on here or is that a normal issue?
So I had to get ski over to landing and started on my way just idling, started turning the fuel on off valve, going to off until engine started to kinda smooth out, then I would hit the throttle and turn it just a little to get more gas, and finally it took off and seemed to run good. Then I shut it off and let it sit for a few minutes, started it up and it did the bog thing again like the plugs were fouled, messed with the fuel selector again and she starts running good again.
Should I try new springs, reset pop off, put new needle and seats in?
or is there something else I should look at?
Sorry about the long post, just trying to give a good explanation.
Thanks Tim
Thanks Tim
