Mr. G
Hi! I am new here but i have alot of car background as i teach shop at a local high school but hopefully you can help me with this SeaDoo. i have a 96 spx just put back together. ran like crap above idle so i replaced all the fuel lines, and thoroughly cleaned carbs and filters. took it out and it was a rocket but died out. bat light would flash intermittent, ended up being a loose ground cable. i tightened ground and found the small black ground from MPEM and ran it to the battery as well as the block. Seemed to run great so i took it out again (this time with the wife!) and rode for about a minute and it died out suddenly, guages still worked. When i went to restart it cranked kinda slow like the battery was weak or resistance on the engine. it is a fresh rebuild but i dont trust the oil injection and i dont know if i should remove it. it got towed back and i charged the battery (with cables hooked up, i know now to unhook when charging) got it to start on land but alot of water blew out of the muffler. could that be from the maniac towing me in at fast speed filling the eng and exhaust? well anyway with the engine running it only makes 13.1 volts when its cranked up high, no battery light on. could the loose ground or me charging it with cables on have cooked the rectifier? the stator has resistance it just seems like a car alternator when a diode goes bad and you only get partial voltage. i was wondering if it would run for longer than a minute on the new battery if it was still charging at 13.1 or is my stalling problem something else. please help me as i would like to take it to the cape tomorrow if possible, i dont care if i have to keep charging the battery. no local dealers have a rectifier. thanks in advance!!! P.S. sorry for writing a book but i want to give all details
