jclack
Hey, Folks,
Noob on this board and w/ SeaDoo, although I've been boating for decades. I've acquired a 1996 Speedster with a few electrical "issues." I was able to figure out a few of them by lurking here (thanks!), but a few are still eluding me. I've searched this board quite a bit and I can't find anything that is similar.
Basically, the blower has no power and the bilge pump doesn't operate automatically. Everything else works, including the direct switch for the bilge pump. I've been busy w/ my multimeter/outside battery and this is what I know:
1. The bilge pump and blower are functional. The bilge works w/ the switch and the blower works off of an external battery.
2. ALL fuses (both in fore compartment and in the electrical box) and switches are okay (confirmed w/ multimeter).
3. Nav lights work fine.
4. System charges fine.
5. No 12V that I can see gets to the blower switch or to the water sensor.
Now, many have talked about a separate wire that goes to the battery which might power these. There is no evidence of one in my 96, and it appears that the power comes from wires embedded in the MPEM (gulp). The wiring diagram is not clear, but it does seem that power goes into the fore fuse block and is distributed to the various devices, some of which work and some of which do not.
I'm starting to wonder it I have a bad fuse block. Any other possibilities that you can think of?
TIA,
Jim
TIA,
Jim
