Hi
I just bought a 96 speedster with twin 717 engines. I have never owned a jet boat or any boat for that matter. That being said ,i have a few questions. I bought the boat from a older couple that I work with who have owned it since 2001 and have only had it out a hand full of times. They took it in to have the once over when they sold it to me. He changed plugs and pump oil and i then bought it.
They had a friend of theirs that has maintained the boat before take me out for a demo in the river. It took off and seemed to run well at first, we got a faint alarm code (possible over heat from debri sea weed and such at launch site).
Alarm went out and we tried third pasenger (total weight about 600lb). Had issue with getting on plain, moved third to front and seemed a little sluggish.
He told me we probably picked up debri and to flush it out when I got it home.
I downloaded the operator guide and the shop manual and i'm having a couple issues.
I found the(Tuned pipe bleed
hose injects water
into muffler to
cool exhaust
components)had a hole in it. I changed hose,I wonder if that could have been causing semi warning beep?
The question finally.
Flushing...
The flushing connector under the hood and the one at the rear seem to meet at a T and go the same place. It appears that they both flush the engine and you have to . 1 start engine . 2turn on water 3 run a couple minutes 4 turn off water 5 turn off engine 6 repeat for other side.
How do i flush the pump? I was told bottom connector flushes pump, but it seems they both go to same T connector. Can the impeller be flushed to see if it has a clog? I dont want to drive 100 miles to lake and find i have a problem. Do people use these on rivers and is there a after market part to screen impeller? I'm itching to get this out on the water but I want to be prudent and not cost myself a ton of $!!!
Thanks and any other info would be much apreciated...
I took boat out yesterday and port engine overheated. Waited for it to cool and found another hose to exhaust blew. made repair on boat and it seemed to fix problem until i slowed down and warning beep came on. Let cool again and started while my son kept an eye on engine for water leaks. As engine reached higher rpm water could be seen leaking from were engine meets exhaust. Shut off and limped home on 1 engine. Is this a blown seal or gasket or something worse?
hose injects water
into muffler to
cool exhaust
Flushing...
