Milemarker81
Howdy.
It's a bit of a story so here goes:
About two weeks ago the port engine cut out on me so I limped home on the starboard. It was slow but no issues.
The brass valve gear had gotten trashed so I pulled the engine, cleaned it out and replaced the gear. I reinstalled and all's good with that engine now.
But, out of nowhere, the starboard now refuses to crank when the spark plugs are in.
I've tried battery and new aftermarket starter. Still no luck.
I've read about some sort of hydro locking but that doesn't seem to fit because nothing but air comes out of the plug holes when I crank it with the plugs out. I clamped off the oil supply hose at the tank when pulling the other engine and had to add two quarts when i removed the clamp after the port engine was reinstalled.
Any ideas?
Thanks in advance,
Rob
Any ideas?
Thanks in advance,
Rob
