Mitch619911
So we got the starboard side engine to fire up and runs super great (always starts right up) but the port side engine is not wanting to start.
It just keeps cranking and cranking, it has a spark I don't know if it's weak or normal, we switched spark plugs with the running engine and that did not work (the other plugs work fine in the good engine).
The engine did want to start a little bit but it just dies, probably fires 2 times, when we first got it out it was running but kept shutting down after a few seconds (10s to 60s?). The good engine ran but it seemed like when we started the bad one they both died... Good engine seems to run fine without the bad one trying to start.
We did try starting fluid directly into the cylinder and it seemed like it did not want to start (but it had spark?!?) last we tried it wanted to start for 2 seconds then die and we have up and took it home.
Also before we brought it to the ramp they both fired up and ran for a good amount of time.
Could it be the dess? Mpem? Main brain? Any questions or answers would be very helpful, we intend to try to keep working on it tomorrow!
Thanks everyone!
Thanks everyone!
