96 sea doo xp
ninerfaithful
WOW.. Well today I went out after I had hesitation problems at fuel throttle. I cleaned both fuel filters one in front with tank and one in carb. It ran hard for the first few laps of the lake but then started hesitating again. Still have grey fuel lines. I'm going to change these this week. I cleaned the rave valves.I ran it on fuel set to reserve cause when on regular fuel it wont go more than ten miles per hour. bogs alot. but in reserve it hesitates now. what do I need to do now.
clean or change the fuel valve the on/off/reserve they tent to clog expecially when you have the grey fuel lines .
if you have the 800 motor you have dual carbs, each with its own filter inside. I would also check for air leaks on the entire fuel system and for sure change that old tempo fuel line.
