Dreed3345
I have a 92 580 won’t start I cleaned and rebuilt carb ,single carb ,not mikuni kit ,yes I will hear about that, will run if a little fuel in carb for a second,hooked up a line from a can to bypass lines won’t start, sucks fuel up from a can,took carb back out fuel is in both sides ,jets ,idler screw all clean blows out carb cleaner ,needle valve seat springs ….weal pulse line? Will not make it to Venturi or plugs. Will not suck to fill up water separator/filter with lines on , cleaned reserve run off valve, blew air in,vents and gas lines bubbles in tank, can I have the one way valve block reversed I don’t see how, on the plus side I’m a pro at getting carb out in record time three times now ,good compression ,low hours , I have owned this since 93 lots of years never saw water does not have the grey lines any thoughts would be appreciated
